Hey Mostapha,
I’m developing a fairly simple solar fan for a prospective tower. When I change the scale factor for the solar fan component the geometry actually changes (probably a result of the loft?) although that’s clearly an error. See the attached images where I change the scale factor and the incidence of the fan on the tower changes significantly.
Any thoughts?
Thanks in advance!
Jeremy Bamberger
