Hi everybody,
I should run a solar analysis for a concrete panel, to get the total radiation. I don’t know how to get an output for the geometry with the material. can you tell me how i can plug the concrete geometry to the analysis button?
yes, this is for a geometry without material. I want to test a geometry with concrete material
You need to use HB instead of LB. Then you will be able to define the properties of each surface/geometry.
Ok i will try it. Thank you
