Using the HVAC System Type 7 Template fairly unaltered except for the addition of a return plenum.
I have 12 floors in my building, so it is creating 12 air loops. When I try to run I get this error:
Program Version,EnergyPlus, Version 8.9.0-eba93e8e1b, YMD=2019.04.11 15:55,
** Severe ** [Coil:Heating:Water][Coil Heating Water 56] - Missing required property ‘water_inlet_node_name’.
** Severe ** [Coil:Heating:Water][Coil Heating Water 56] - Missing required property ‘water_outlet_node_name’.
** Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
…Summary of Errors that led to program termination:
… Reference severe error count=2
… Last severe error=[Coil:Heating:Water][Coil Heating Water 56] - Missing required property ‘water_outlet_node_name’.
************* Warning: Node connection errors not checked - most system input has not been read (see previous warning).
************* Fatal error – final processing. Program exited before simulations began. See previous error messages.
************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
************* EnergyPlus Terminated–Fatal Error Detected. 0 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 0.42sec
Looking inside of the OS file, I see that the cooling and heating coils on the supply equipment are missing, except for the twelfth and final loop:
Any idea why the coils are not translating to all but one of the air loops?
