Hello, I want to vizualize my energy balance monthly. Everything shows perfectly except the everything related to HVAC. It shows me an error related to my HVAC modelling being too detailed. I have followed what the warnings says that I should do, but still it won’t work.
The following Rooms use HVAC systems other than Ideal Air.
The cooling and heating results for detailed HVAC are electricity and
fuel, which cannot be used in load balances of thermal energy.
Either replace these detailed HVAC systems with Ideal Air Systems or
use the “HB Annual Loads” component to get a load balance these
roomswith detailed HVAC:
COMBLE
LOCAL ENTREE EAU
ESC - APP - SOUS SOL
ESC - APP - ETAGE 2
ESC - APP - ETAGE 1
APP - SOUS SOL
APP - ETAGE 1
APP - ETAGE 2
@AESB99 So like it says in the error message, detailed HVAC doesn’t work with this component and HB Annual Loads should be used in it’s stead.
The HB Thermal Load Balance component checks for whether or not rooms have ideal air or other hvac, and will only work with ideal air HVAC.
