COP and ERR properties of HVAC systems
Hi Everyone,
I did simulation for a single building with various heating systems, such as air source heat pumps and water source heat pumps(using HB HeaCool HVAC template). My question is, is there any component that I could extract directly corresponding cop/ERR of the simulated system? If not, with the available components, how can I manually calculate them?
Many thanks in advance
Hi @Elenai, you can use add_str_ input to add an output of the simulation for COP
for instance:
Output:Variable,
  *,                         !- Key Value
  VRF Heat Pump COP,         !- Variable Name
  hourly;                    !- Reporting Frequency
the file to get the output variables is the *.rdd file created from the simulation.
and to get the results you would use something like the following:
Hopefully that’s helpful
