Create HB Room from HB face do not form a closed volume
Hello @prashhh ,
I would suggest a couple general things to get you started:
  1. Definitely check out some of the learning resources for Honeybee and Ladybug, for instance this tutorial series here:
    https://www.youtube.com/playlist?list=PLruLh1AdY-SgW4uDtNSMLeiUmA8YXEHT_
  2. I would also recommend checking out:
    Step 0 - Modeling Zone Geometry | honeybee-wiki
  3. And also: Introduction | Ladybug Tools Academy
  4. Remember that no one else has access to your computer or Rhino model, so when providing a Grasshopper model to this forum, you should first ‘internalize’ the geometry into the ‘.gh’ file - otherwise no one will be able to run the script or provide much assistance.
To your specific question here though: you need to put the faces together into a ‘Room’ first:
best,
@edpmay
