Hello guy, Im a master degree student on Computational design. Now i have a project to design the habitat on mars so I try to make a Mars weather analysis with grasshopper. I got the CSV Mars weather from this Link:(data/mars-weather at master · the-pudding/data · GitHub) and I have a problem to convert CSV file to epw. If who guy know how to make it pls shared your experience. THX
The epw file is just a text file. So if the CSV is alreadt in the right format you can just change the extension. If the format need to change then I would advice the following:
Change manually using a spreadsheet program like Excel.
Energyplus comes with a ‘Weather statistics and conversions’ tool. Try searching for that terms or look in the directory:
YOUREPDIREnergyPlusV8-5-0\PreProcess\WeatherConverter\Weather.exe -
The Elements tool by big ladder might also help:
Elements | Big Ladder Software
This post might be interesting aswell regarding the topic:
if u have converted that CSV mars weather data to EPW,can u plz share it
Any feedback from the user ? No problem ?
