Hello!
I have a problem. I would like to run an annual daylight, but i have a report.
Somebody also had this problem? Do you know any solution?
Árpád
Hello!
Árpád
I already downloaded the latest plugin, but does’t work. Sorry but I’m not very IT oriented, how can I share the log file and where can I find it?
Hi @Hajdu,
There is a file in the __logs__
folder in the project folder. You can upload the file logs.txt
here or via a shareable link on Dropbox, Google Drive, or something else.
Hi @Hajdu,
There is nothing wrong with the logs that you shared. Make sure to select the failed study if you still have the issue.
