Hi there!
I am researching the influence of local weather on the energy consumption of buildings. I have weather files with hourly inputs from the site to be analysed: I would like use this measured weather data instead of using the ASHRAE Default Temperature range multipliers as the differences in the measured and modelled temperatures are significant.
Is there a way to implement this? DDY files have the option of TemperatureProfileSchedule as multipliers, however this option is not available in the construct design day plugin.
Kind regards,
Gustaf
