I would like to compare the performance of 3 different wall heating systems:
Low-temperature area wall heating system: wall heating system with parallel pipes
Radiative high-temperature system 1: a radiative plate heater
Radiative high-temperature system 2: a Temperierung system that heats the base of the wall (two copper heating pipes in the base area of the outer wall and a second loop at height of the window parapet heat the wall).
@MingboPeng, Yes I tried adapting the sample mentioned above with my version 1.1.0 of HB.
However it seems like I miss some components, because I am not able to find the radiant system option:
