Hello, how can I use an edited EPW file or Dragonfly alternative weather file for simulation? Since most of the examples are shown for visualization purposes. Therefore, for example, the dragonfly alternative weather file outputs data, however, I am unsure of how to use it to let’s say simulate a new energy simulation? @chris
Hi @Latifah ,
I am not sure that I understand your question. Are you saying that you have built a new EPW file using some of the components like those in this sample and now you’re wondering how to run an energy simulation with it?
If so, just plug the path to the newly-generated EPW file into the HB Model to OSM component that is used to run energy simulations and then you’ll be running an energy simulation with your new EPW.
