Hi Mostapha, Chris and rest of the ladybug team!
Is it able to embed PCM in EP window construction?
I went through the old discussion in PCM material, “additionalStrings” method is working in normal building construction.
However, since PCM needs to be assigned the thermal property, it has to be an opaque material. Then it will not work while I try to make a window construction.
Therefore, I am wondering that if there is any solution for this?
I upload a WIP file, and thanks in advanced.
0510_PCM volume testing.gh (827.4 KB)
