Creating Stat files from EPW
Is there a easy way to generate Stat files from EPW files?
I tested it with creating weather formatted data in energyplus. And it works, is this implemented in Ladybug?
Thanks
Best regards
Tobias
The EnergyPlus WeatherConverter utility is the way to go here. You can see it referenced here in this unmethours issue:
We don’t have any Ladybug Tools component that does this STAT creation now but, if we ever were to add a component that does this, it would just call that EnergyPlus utility under the hood.
Thank you chris! I will be using the Energy+ converter.
Best regards
Tobias
