Hi!
Actually I want to run an annual radiation analysis in the inside of a greenhouse. CM-sky I suppose is the right one, at least it gives me the possibility in defining an analysis period. But it’s actually not running… Any idea out here? Could it be the connection btw. the skyFilePath and the _skyFile?
THX,
Daniel
read-me output ::
Grid-based Radiance simulation
The component is checking ad, as, ar and aa values. This is just to make sure that the results are accurate enough.
Good to go!
Current working directory is set to: C:\002_VIDEO\02_UNI\TU_GRAZ\01_DISSERTATION\02_RESEARCH\08_POMODORO\01_SIMULATION_MODEL/03_HONEYBEE\VF_00\gridBasedSimulation<br/>start cmd /c C:\Users\paratufello\AppData\Roaming\Ladybug\unnamed\annualSimulation\unnamed_7_DS.bat
WMIC PROCESS get Commandline
Runtime error (IndexOutOfRangeException): index out of range: 0
Traceback:
line 271, in script
Hi Daniel,
Attaching your file can be more helpful … if posible.
Runs fine on my side after i disconnected the panel with the Folder Name. I’ll bet it is because the blank space in 01_SIMULATION MODEL.
Cancel this space and it will work.
THX, but no change.
Have a look on the reply to Mostapha…
D
