Hi everyone,
I want to create a custom insulated concrete wall and be able to change insulation thickness in order to adjust the wall’s U-value. Initially I tried to do it using existing materials but I noticed that, for example, insulation had a thickness of 20mm (while in my case I need to have from 100 to 200mm of insulation). So, I created an EP Construction using
a.an EP opaque material to create the insulation,
b.a number slider to adjust the insulation thickness and
c. a concrete wall from the EP library (I selected M15 200MM Heavyweight concrete).
But:
When I changed the insulation thickness, the final wall U-value did not update. I had to recompute everything in order to get the correct number.
After having this issue, I created different insulation materials with different thicknesses (one 150mm and one 200mm) and two different wall types (respectively) but I got a lower U-value for less insulation which did not make sense (see Picture 1), so I assumed that this was happening because I had used by mistake the same material name. Therefore, I changed the names (let’s say insulation1 and insulation2) and now… I get another error (see Picture 2) and I don’t know what to do next.
Therefore my questions are:
What am I doing wrong?
Is there a way to parametrically change material thickness, so as to use it as a gene for optimization? I also attach the definition
Thank you for all the help!
honeybee_custommaterials.gh (484 KB)
