I’m working in Grasshopper using Honeybee/OpenStudio and trying to extract results with the Custom Result component. The simulation runs successfully through ModelToOSM, but the Custom Result component is not returning any data. I’ve connected the SQL output and used output names like “Zone Outdoor Air Flow Rate” and “Ventilation Air Flow Rate,” but the results remain empty. I’m not sure if the issue is due to incorrect output variable names. Is there a specific format or exact naming convention required for the output names to retrieve results correctly?
Hi @Lilith , that is almost certainly due to a mis-match with the variable names. You should usually run the simulation once, take a look at the resulting ‘.rdd’ file, and then use the names from there directly (copy / paste, don’t try and re-type - the spelling matters). For reference, take a look here:
Take a look here:
Note, if the name you want isn’t in the RDD, you need to add it as an output variable before running the simulation.
best of luck with it
@edpmay
@edpmay thank you. you were right.
