Hi, I must say i really like the new HB[+] workflow and update, great work @mostapha and @chris!
I would like to test out integrated shadings from Microshades for both thermal and daylight calculations. I did find these Rad material files in addition to the BSDF XML file on their webpage. What is the best approach for integrating this to the workflow with HB[+]?
I see that the RAD file refers to the CAL file, do I need to place it in a specific folder for the project, or is there a RAD library i can place it in? Where can i find the radiance modifier library?
MicroShade_mat.rad (216 Bytes) MS_D.xml (827.5 KB) microshade_d.cal (3.1 KB)
