Hi!
Can anyone help me with this error?
When I connect panel to difRad I face this error
Update honeybee[+] to the latest version. Here is how: Honeybee[+] update component error: Solution exception:WindowsError
Did you also update the file? You should replace them with the newer version of the components.
Hi @mostapha,
I have the same issue even after updating the HB+ and replacing components with a new one. I think in my case, it is due to the LB+ update. When I installed HB+, LB+ was not in the path and I added it from my own archive (sometimes before it was installed on a system that I worked with!). I tried the installmeant process on different systems but I had the same result of not LB+.
Interestingly, with the old version of HB+ (0.0.004) all is fine and custom sky works well. I also do not have the LB+ installment issue.
The thing is that all my project is made with the latest version of HB+ and would be great to not work with the old version.
I am wondering if you have any comments that where I am wrong and how to solve this issue.
I have uploaded pictures here for your view.
Thanks
I might recommend just using the latest development version of the LBT plugin instead of HB[+]. All but one of the Legacy Radiance recipes have now been implemented in the LBT plugin and they will all be in LBT 1.3 when it’s released.
