Hello everyone,
I’m following this example to run integrated daylight and energy simulation for an office room. Using HB_Create CSV schedule, I tried to create customized schedules (as shown in the pictures) and this component seems working fine but apparently when I want to call the CSV file for occupancy schedule (input to HB_set Zone Schedules) and also to update the lighting schedule (input to HB_readAnnualResults I) it cannot be set correctly.
I tried to run the simulation with the default occupancy schedule for “closed office program” and it works. when I compare the created CSV file with DAYsim CSV occupancy schedule there are some points of difference:
For customized CSV schedule (occupancy, equipment, and ventilation)
- The month starts from 0!
- There is an empty column under the headline of “values” and the next column is set to “Values” with 0/1 numbers I put them in my definition.
Should it be a problem because of these differences?
I also attached the CSV files created by the component here.
Many thanks for any help and recommendation
SCHOccupancy.csv (149.6 KB)
SCHVentilation.csv (149.6 KB)
