Hi guys, when I run analysis with DirectSunHour, I feed in, in this example, 34 meshes as input geometry but it send out results as a flattened list of each grid I divided in advance. I wish to get the result by the structure with 34 branches so that I can align the results with the input 34 meshes.
I found a similar thread but it didn’t get a solution.
I can’t run your sample file because of all the other plugins it depends on but just graft the _geometry input to get a separate branch for each input.
