Sorry for the late reply. I just tried to check but you forgot to internalize the geometry in your file. Can you upload your file again if the issue is still there.
I downloaded the file from our converstation and internalized the geometry and suddenly the mesh now appears correct!
I am running the analysis in a laptop with one core this time. Could that be a reason for the difference! I will re-run it in the PC I run the original analysis tomorrow and see what happens!
Well, what I can see in your image should be reversed to be accurate! Let me know about the update. It might be the issue with reading the results for multiple CPUs.
I use the Less Than Range output as values so it makes sense to be inverted.
I tried also with the inTheRange at my desktop…and things seem to be working great.
No idea why the original weird “split” analysis occurred…If I haven t saved the image I would doubt myself it ever happened… I attach the file for future reference.
May I ask:
How much should we worry about the CreatHBSrfs alerts regarding the normal direction:"Normal direction of the surface is not expected for a FLOOR. The surface is more likely a ROOF.Honeybee won’t overwrite the type so you may need to manually flip the surface."?
