Daylight compliance with EN 17037
EN 17037 specifies that daylight calculations should be carried out using validated software.
I am applying all the requirements defined in the standard, so my question is: is there any official procedure to assess the compliance of Ladybug with the standard, or can Ladybug be considered compliant with EN 17037 requirements when the settings are correctly defined?
Do you have any advice on this topic?
Thank you in advance,
Erika
Hi @erikas
LBT is a plugin covers simulation software such as Radiance and Energy Plus. as a result , it is better to refer to Radiance and daylight metrics
