Daylight Factor error report (ver. LBT 1.2)
Dear Ladybuggers,
I try a Daylight Factor analysis with the new LBT 1.2 component, but I run into this error, which I cannot resolve:
Runtime error (DecoderFallbackException): Die Bytes [E4] im Index 0 können nicht von der angegebenen Codepage in Unicode übersetzt werden.
Traceback:
line 47, in py_encode_basestring_ascii, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 390, in _iterencode_dict, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 332, in _iterencode_list, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 408, in _iterencode_dict, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 434, in iterencode, “C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json\encoder.py”
line 189, in dump, "C:\Program Files\Rhino 7\Plug-ins\IronPython\Lib\json_init
.py"
line 31, in model_to_json, “C:\Users\rvg\ladybug_tools\python\Lib\site-packages\pollination_handlers\inputs\model.py”
line 442, in handle_value, “C:\Users\rvg\ladybug_tools\python\Lib\site-packages\lbt_recipes\recipe.py”
line 76, in script
line 169, in write_inputs_json, “C:\Users\rvg\ladybug_tools\python\Lib\site-packages\lbt_recipes\recipe.py”
line 240, in run, “C:\Users\rvg\ladybug_tools\python\Lib\site-packages\lbt_recipes\recipe.py”
Hier the attached File with the internalised geometries
LBT_1.2-DF.gh (896.5 KB)
could someone explain to me where the mistake could be?
Thanks
From the error message, it’s probably a non-ascii character in one of your inputs. Is that the case here?
@chris and @MingboPeng, this is something that we probably want to support by default.
Dear @mostapha
You’re right, the name of the material and from the HBface had an Ä.
By removing the “umlaut” it works
Very very thanks
Hi @LaFleur, thank you for letting us know. As I said I think we should handle such cases by default. Good to know that there is an easy workaround for now.
if it is of interest, the component HBFace that had linked the name containing a Non-ASCII letter, could not be updated by the GH Sync. Without the Non-ASCII letter, could be!!
Best regards
