Good morning,
I am developing a Grasshopper definition (Ladybug/Honeybee) for daylight analysis in a high school classroom.
I am focusing on:
Daylight Factor (DF / FDm)**
sDA (spatial Daylight Autonomy)**
Glare (DGP/DGI)**
I have internalized the classroom geometry (4 large vertical windows), but I am encountering some issues with the results.
- Daylight Factor (FDm)
Despite the presence of large glazed openings, the FDm value is still below 3%.
I would like to understand:
whether I am making mistakes in the model setup (materials, sky, Radiance parameters, etc.)
or if the result is consistent with the geometry (room depth, window position, etc.)
- sDA
Regarding sDA, I am unable to meet the requirement:
sDA ≥ 95% of the points with **≥ 300 lux for at least **50% of daylight hours
Questions:
- are the parameters I am using correct (illuminance threshold, sensor grid, etc.)?
- is it normal for a classroom with these openings not to meet this requirement?
- Daylight hours (sDA)
I have a specific question about the calculation:
Does sDA automatically consider the 50% of daylight hours
or
do I need to manually filter the hours (using schedules or HOYs)?
- Glare
I am also performing glare analysis using views and DGP/DGI.
Any suggestions on:
correct view setup (fisheye, observer position, direction)
how to properly evaluate glare across multiple points and directions
would be appreciated.
Objective
I would like to understand whether:
the results are physically consistent
or there are errors in my simulation setup
Thank you in advance for any feedback.
Luca
https://drive.google.com/drive/folders/1qHSF_DZaxbD7iVW7lEZA4UZEayLv8tYL?usp=sharing
PS. I can not upload files here. I don’t know why.
