Hello everyone,
I am trying to optimize daylight-integrated lighting energy simulation. When I use components in Legacy and turn on ies files for lighting fixtures, the simulation tools 8 minutes. So, I try to use my DA results from LBT. But. When I try to add my Annual results .ill files to readAnnualResults, it gives the error tells 1. Can’t sort .ill files based on the file names. Make sure branches are sorted correctly.
I feel stuck and can not move forward. Is there any solution for me to move on, either make the first simulation attempt faster or connect the second solution without errors?
The other problem is that when I move forward with a longer simulation, I get stuck on the energy plus component. It tells me that there is no file. When I try to visualize the results of EnergyPlus, the readEPResults component can’t find the file even though the input says there is.
On the other computer, it can. What could be the reason?
Thanks a lot.
Pelin
