I’ve started using Grasshopper recently and built up this energy & daylight analysis analysis based on Mostapha’s example file.
I added zones because I want separate lighting schedules for each perimeter zone but I can’t seem to visualize my daylight results. I’m trying to use the recolor mesh component but the number of results points is five times as long as the number of points in my mesh. I can see the source of the error using param viewer - I do have (for example) 100 points in my mesh, but 500 results points from the UDI output. I’ve included a screenshot of the error, plus a screenshot of the param viewer “mismatch” and my grasshopper file. My gh file is large but I’ve grouped the problem areas in orange.
My initial guess was that it was calculating daylight results for each zone and for each mesh (5x5)?
I’m also having trouble with my EPConstruction and RADMaterial items. They seem to work initially when I copy them from another file but they frequently “fault out” giving the error to Let Honeybee fly or Update Honeybee. I’ll re-update HB, delete and re-add the components and maybe get them working again but it’s happened so frequently I’m not sure if there’s something else causing this error.
