Hi Everyone,
I’m conducting research on daylight performance on
minimal surfaces, which often result in spherical or cylindrical shapes. I have a couple of questions:
- Are there limitations in daylight simulations using Ladybug Tools (LB Tools) when working with non-planar walls?
- I’m encountering an error from the “HB add subface” component with my current geometry. Could someone help troubleshoot this issue? I’ve also faced similar errors with other geometries recently.
I believe I have no window-to-wall projection issues with this model, but if there are any components that can streamline or troubleshoot the projection process or help resolve this error, I would greatly appreciate it!
Thanks in advance!
Here’s the file:
Daylight test.gh (62.3 KB)
