When I used the batteries from honeybee-legacy to write rad files for daylight simulation, I found some problems if I turned two batteries into one cluster such as SetOpaqueMaterial + HoneybeeSurface:
However, if I didn’t turn these batteries into a cluster, then the simulation can be run smoothly.
Any tips for packaging a cluster under Ladybug or Honeybee?
