Hi Mostapha,
I’m using both Honeybee and Ladybug for running multiple iterations of energy simulation. During the calculation process, sometimes Daysim will crash, thereby causing the “Honeybee_Run Daylight Simulation” component to give errors while the other components for both Radiance and Energy Plus running properly.
Colin mentioned to me earlier that this problem had happened before, does anyone have clues yet what might be causing the problem?
p.s. I’m using EnergyPlus-8.4.0. Sometimes reruning the “Honeybee_Run Daylight Simulation” component will fix the problem, but it seems like impossible while “Ladybug_fly” component just keeps running the calculation running one after another even if Daysim crashes.
