Decimals in the results of daylight factor (annual analysis)
I’m doing an annual analysis with honeybee plus. I use the “radiance analysis " component and then the " honeybeeplus_cumulative value” component to have one value for each mesh. But my results (daylight factor) have no decimals, there are simply 1 or 2 and I need to have at least one decimal.
Can someone tell me how to change this ?
Thank you
Please see this
Hello @julia.serriere, It appears that you’re missing an avatar! Please set it up in your profile! Thanks. :slight_smile:
Hi Devang,
Thanks ! that helped :wink:
