I’m using the v 1.3.0 build from yesterday. When deconstructing program areas to understand individual lighting and equipment loads I see errors for specific program:
- Input parameter _lighting failed to collect data!, and
- Input parameter _equip failed to collect data!
The large office is returning null data when I use the lighting and equipment components.
If I switch to the medium or small office it works fine
The Strip mall shows the same error only for lighting.
Both the Full and Quick Service Restaurant have errors for both lighting and equipment.
The other programme areas seem fine.
If I plug a panel into the lighting output of the HP Deconstruct Programe Type I can see the values (refer images) but it seems to be failing to parse these for certain programe types.
Thoughts welcome.
Sean
