Default Material Properties
Hi
I am aware of that honeybee will take default materials for HBSurface based on surface type.
Where can I check the default material properties in HB? (for example, U value of the default wall or u value)
Furthermore, I would like to know the information regarding the values derived from the building program, when we use ListZonePrograms.
It will be much appreciated if you can give me some information regarding this matter.
Thank you!
Following is what you can do.
-Devang
thank you!
  • john
Hello Devang,
I have the same problem, but the image you uploaded is unavailable. Would you mind uploading it again?
Hey @Zhinarashidzadeh,
That’s quite an old post and I am afraid I cannot upload the same image. I believe you should start using LBT plugin rather than using the legacy plugins.
@devang, thank you for your response. I ran all my simulations with HB-Legacy and extracted almost 500 data. I am writing a paper about it, and I was looking for the default materials that the legacy plugins use to report in my article.
