Design Explorer Not Uploading Data
Hi everyone, @MingboPeng
I have been trying to upload some data on Design Explorer with no success. I have followed the usual procedures before and managed to upload data before but somehow this time its not working.
The shareable data is found here
https://drive.google.com/drive/folders/1xo9LH5fGda71aeowT8xfRSKARAIT28u-?usp=sharing
May you please assist?
Please check your header: image
you have two columns (headers) for image, but only “img_1” has image files. you put threeD files under img_2, and left threeD empty.
Just rename “img_2” to “threeD”, and remove column R will fix the problem.
Thanks a lot @MingboPeng, I realized where the error came from, I was intending to export 2 Named Views from the Rhino scene, and I had issues with the multiline command in the panel where the names of the views were typed. Thanks a lot!
