I am trying to perform a detailed thermal comfort analyses with HB.
I have used some of the example files for learning how to create the code structure but I still have several issues if I want to personalize the code.
Think about a simple box with a couple of zones and a window for each zone. I would like to define all the parameters (U value, SGHC, etc.) without using the EP library. I found the components but I have some issues to combine them in a correct way.
Furthermore I would like to set my own schedules and internal gains, without using the default programs. I am quite sure it is possible because there are components which could fit this, but I have still not found a way to make it work.
Could you please help me?
My final goal would be to combine thermal comfort and daylighting analyses in order to find the best temperature set points according to glass properties.
Most importantly you must make sure that all your Honeybee components are up to date. If they are not this can (and will usually) cause chaos make sure your honeybee components are up to date by downloading them from user objects on github here: https://github.com/mostaphaRoudsari/Honeybee/tree/master/userObjects
Ive outlined how to set schedules and loads in the GH file
Don’t use join to join your HB surfaces together you can simply put them into the Create Honeybee zone component
Thanks for taking care of this, Anotn. Riccardo, I just wanted to let you know that there are many levels of detail to comfort analyses depending on how deep you want to go. For just a single time series of PMV for each room, you should use the example file that you started from and this video playlist as a guide:
