Hi @AntonelloDiNunzio, first of all thank you so much for df envimet plugin! I am new to it and I have a question regarding the grid.
As you can see from the picture, the grid extended 5 cells on the x and y axes (3 on one side and 2 on the other) from the baseSurface, even if I explicitly set addCells and NestingGrids to be 0. The 5 additional cells appear also in the ModelInfo of DFEnvimetSpaces and they count for the 50x50x40 limitation of ENVI-met LITE. However, they are treated differently from grid cells, because DFEnvimetSpaces complains if any object is less than two cells from the grid border, meaning the baseSurface border with no additional cells.
So, are these additional cells like “fixed” in your configuration? are they “normal” cells or nesting grids? Is there a way to control them? I know that a certain space on the border is paramount for a sound CFD simulation, but I am still experimenting with ENVI-met LITE, so each cell counts
