I have problem when I use recolor mesh and any other ways to show my DF simulation results. I use a simple rectangular room with just one window and use brep to use it in grasshopper. When I use outputs, it gives reverse DF amounts so that near window grids have less DF amount (about 82%) than other parts (100%). Actually, it is like the window is calculated for the other side of the room and this problem bothers me a lot. I upload my files to clarify the problem. Thanks.grasshopper filerhino file
can you please share your file.
I thank you a lot and shared both my Rhino and Grasshopper files. Thank you.
error.rar (565.8 KB)
the procedure you followed is correct, please check glazing surfaces input .
