“DF RUN URBANopt error”:Solution exception:The URBANopt simulation failed to run.No results were found at: C: \ Users \ HP \ simulation \ kkpp\ run \ honeybee scenario
Hi Chris, Thank you for your prompt response. I will try the Pollination Grasshopper installer later. Also, I tested the versioner component again and got some error reports, as shown in the picture. It is possible that these reports could explain the reason why the version control feature cannot run properly.
It would be great if you could provide me with some guidance. Thank you!
