I thought that if a high-luminance light source like this is within the field of view, the DGP would be quite high, but it’s almost close to zero. Why do you think that is?
when view direction is facing the sun point, the DGP still comes out close to 0.
Hi @seojeonghwan,
You cannot connect the falsecolor image – you must connect the raw HDR from the recipe component.
Thank you so much but I still wonder the DGP value is reliable when the glare source is located at the center of the visual field.
As long as it’s within the visual field, even if it’s not at the center.
