Differences between "ventilationPerArea" and "ventilationPerPerson"
By using the “Honeybee_Set EnergyPlus Zone Loads”, if I want to set the whole zone’s machanical ventilation rate, should I use both the “ventilationPerArea” and “ventilationPerPerson” together?
Or are these two inputs actually the same thing that
“ventilationPerPerson"×"numofPeoplePerArea”=“ventilationPerArea”? So should I only input one at a time?
Hope someone can help me with this question, thank you in advance.
@skyly It is a simple question. According to ASHARE 62.1-2010, outdoor air flow is sum of the ventilationPerArea and ventilationPerPerson.
Hi @minggangyin, thank you for the reply! The table is really helpful.
