Different results on different computers
I have analyzed a daylight simulation algorithm (the same algorithm) on 2 different computers with windows 64,
but the results are totally different,
I am confused… What do you guess the reason might be?
Are you able to show us the results, along with the inputs you use to do the daylight simulations?
My guess is that an input within the file is different. I am not sure if different versions of E+ or Daysim would matter, but it does seem odd if you are simply using the same “imaged” computers and the same gh file that the results would be different…
Radiance uses a stochastic sampling for calculation and 5-10% difference is expected. If you want to minimize the difference you can set radPar to be high. Also check this post on Radiance discussion group: http://comments.gmane.org/gmane.comp.graphics.radiance.general/2685
Mostapha
Hi Elzine and Mostafa,
unfortunately I didn’t take a picture or saved the result, actuly it was conclusion of a series of calculation.
but it had difference was high,
for example I tested some WWR according to UDI in Tehran, and the best one was 40% in the first computer and the same gh file on the other computer showed me 16% which sounds wired!
Now, I am working on the second computer and don’t have access to the first one, I guess something is wrong with this computer, I can’t trust on the results! Is there a way I get sure that the results are OK?
Fahimeh,
I think you’re confusing two different topics together. My understanding is that you’re getting two different optimum options based on the result of the optimization algorithm. It can have several reasons such as finding a local optima instead of the global optima, or having a weak objective function. This doesn’t necessary have to do with Honeybee’s daylight analysis. To have a better understanding about what is happening you can re-run the best cases against each other and compare the results. Your problem may have several local optima.
