I am experiencing an issue with my daylight analysis tool in Grasshopper. The script I am using is nearly identical. The primary distinction is that for the first one, I am creating the sensor grid with a tool that generates it parametrically. For the other, I am utilizing the Honeybee ‘Sensor Grid from Rooms’ component. Upon initiating the calculations, these are the results:
The first result is with the parametric tool, while the second one is with the HB component. I am unable to identify the difference in the Grasshopper script. I hope someone could assist in resolving this issue.
