Diffrent controls from the YouTube tutorial
Pleasewhy does the guy from the tutorial have hour, day and year and i don’t.
Please why is everything so different. I’m just starting this
@Milan What you are seeing in the video are components from the legacy ladybug tools, there since has been many many updates and its much better.
If you need references the is a samples library component here where you can select the bug and the type of process or simulation and it will populate on the canvas:
sample_lib
hopefully that helps!
