Hello!
I am doing a sun hours analysis for two planes. I would like to get the total amount of sun hours separately for both of them, but when I take the results from the component It gives me the values for each point in the analysis. Is there a way to differentiate which point belongs to which plane?
do you happen to be able to share an example file? would be easier to try and aide via appending to
I imagine that grafting the _geometry input for the component will give you a data tree with two branches (one for each plane) so that it’s clear which point is for which plane. Still, a sample file would be helpful as @TrevorFedyna suggests.
