Hello, it seems that time step don’t work
The result mesh have all colors of different hours
Did you plug the same timestep into the Analysis Period that you used to generate the sun vectors like so?
direct_sun_study.gh (33.1 KB)
Thanks @chris
In your example using time step in analysis period is enough , no need to plug it to direct sun hours.
If i understand time step in direct sun hours show the results hourly? vector by vector ?
I used list item to select one vector when time step didn’t work, also i plug it in both of them without success
