Hi @mostapha @chris , happy New Year!
As this may have been mentioned a few times on the forum, I would love to see a method to do direct sun only daylight calculation with LBT. I would like to run a ab 0 simulation but I recalled I saw from other posts that the current DC method will not run properly if we set ab 0 in radiance parameter input. In HoneybeePlus we had an option to read direct sun only results but that option is not available in LBT now. My understanding is the DC method already give us the ab 0 results and we just need to expose it.
This may be already in your pipeline as I saw you guys mentioned ASE component a few times. While we are waiting for that, do we have a work around to access the direct.ill files now?
I do saw another post recommending using direct sun component. However, I suspect grasshopper will freak out with the direct sun component on a bigger model.
Thanks.
Bing
