Hello!
I need to use points instead of a BREP surface(s) for direct sunlight hours analysis to generate a 3-dimensional visualisation of how the sun interacts with the site annually. I will do this layer by layer of the site.
I assume there is a way of dividing my site into a defined amount of points, as this is already what the DirectSunHours component does to the input geometry.
I am very new to both grasshopper and ladybug, so it would be fantastic if you could explain solutions step by step if it’s not too much trouble.
Many thanks,
J
