Disable Unwanted output from radiationAnalysis Component
Hi guys,
I want to run an optimization which optimize radiation results based on sun shade parameters.
this component has many out put which is unnecessary for me and time consuming for machine . I need only totalRadiation for this job.
I see the code but its take too much time for me to follow the code and disable the calculation parts. can you help me?
by the way I think its a good idea to let user disable the unwanted output based on their need for better performance :slight_smile:
with the current set-up there is no good way to do that. Once cumulative radiation is implemented in Hoenybee[+] then you should use that to get only what you need.
