I’m conducting a Daylight Autonomy simulation with HB-Radiance 1.6.0. I used both HB sDA and LB Mesh Threshold Selector to derive the percentage of area compliance but found that they produce very different result.
For the analysis plane with most of the area reaching about 100% target time, sDA regarded only 42% as compliant whereas the Threshold Selector showed 96% as compliant. Did I use the sDA component incorrectly or is it bugged?
