How does HB+ generate .wea from .epw file ? Does it use direct normal or direct horizontal radiation?
But, even either of them, diffuse horizontal radiation should remain the same between epw and wea file which I found significant discrepancy here in case of Melbourne climate. In the upper image shows direct normal and diffuse solar radiation from epw file, while the lower image shows the generated .wea file. If you compare the first hours you see they are not the same, in which they have to be the same. Both time steps are for one hour.
How did you generate the wea file? The output of honeybee[+] should be in half an hour timesteps. I also did a quick check and the values are the same:
I noticed my question was not clear at all after reading it again, I apologize for that.
I have created the .wea through DAYSIM 3 itself for 20 minutes time intervals, in which the values for direct and diffuse radiation are different from the ones that HB+ is creating.
The upper image is the one from DAYSIM and the lower one is the same code @mostapha used. It seems HB+ creates it based on linear interpolation which is not the case for DAYSIM.
Now I see what you meant. That is intentional. See this issue on GitHub. Daysim approach randomizes the numbers based on algorithm which I didn’t feel comfortable using for a file that supposed to show a typical weather for a location.
You were saying “If one wants to use Daysim approach they can generate the wea file from Daysim and then use WEA.from_file method to create a WEA object.”,
Now the question is; which is the component to import .wea from a file?
