Hi Abraham,
Thank you for the link. Actually I had already been aware of it. This is why I am trying to run daylight simulation first then pass the generated schedule to the E+ simulation for obtaining energy use of electric lighting dimming system.
But I found a major mistake in my previous test file, that is, the “lighting Power” used in the daylight simulation and the E+ simulation are NOT equal by my carelessness. The former was 250w (default value in “Honeybee_Lighting control Recipe”) while the later was 11.840357150=592.018w (lightingDensityPerAreaAreaoffloor=lightingpower).
Having corrected this mistake (by using 592.018w for both of them), the results of electric lighting energy obtained from daylight and E+ simulations are much closer with each other and more reasonable. In order to see how close they are, I made 3 tests using 3 different weather files (New York, Amsterdam, Guangzhou). The results are listed as follows respectively:
New York (3.4% difference)
Amsterdam (2.7% difference)
Guangzhou (3% difference)
It seems that the difference (around 3%) is acceptable?
You are right. Having checked the IDF file created, as you mentioned above, there is no data in the Daylighting class (since the daylight control are not implemented in the E+ simulation). But, the light is “fully/partially” on according to the “fractions” in the generated lighting schedule list, which already takes in account the dimming system by the setting in “Honeybee_Lighting control Recipe” in daylight simulation.
Then, what the E+ simulation did in terms of calculating electric lighting energy use is just as the following formulation: **lightingDensityPerArea * Areaoffloor * sum of lighting schedule list (generated by daylight simulation in this case) = electric lighting energy use, which has been verified by the comparison of results obtained from E+ simulation and calculated by the above formulation. (The results are exactly the same.) **Please see the updated gh file attached.
Therefore, I assume that the E+ results generated in this way (using the lighting schedule generated by the daylight simulation) are still reliable, although there exist some tiny difference (around 3%) for some unknown reason (Maybe Daysim does not follow the same formulation mentioned above? Can you imagine the possible reason?).
In addition,
I am not clear with what you mentioned as “they definitely don’t share daylight considerations”. What “daylight considerations” here refer to? (sky condition / sky file? but in the annual Daylight Simulation, only weather file is required instead of sky file)
A basic question: In E+ simulation, has the waste heat generated by the electric lighting been considered as “internal heat gain” (showed in the above image)? If so, can I say that “energy use for electrical light” is fully converted to “the waste heat” + “Illuminance in lux”.
Namely, energy use for electrical light = the waste heat + Illuminance in lux (lux can be converted to electric power in watts)?
Many thanks!
Ding
text8.gh (597 KB)
